clear event-history
clear event-history
event-history |
Clears the event history file |
nx9500-6C8809(config)#show event-history EVENT HISTORY REPORT Generated on '2019-02-21 14:21:03 UTC' by 'admin' 2019-02-21 14:20:50 nx9500-6C8809 SYSTEM LOGIN Successfully logged in user 'admin' with privilege 'superuser' from 'ssh' 2019-02-21 14:12:46 nx9500-6C8809 DIAG PWRSPLY_FAIL Power supply redundancy failure 2019-02-21 14:02:42 nx9500-6C8809 DIAG PWRSPLY_FAIL Power supply redundancy failure 2019-02-21 13:52:38 nx9500-6C8809 DIAG PWRSPLY_FAIL Power supply redundancy failure 2019-02-21 13:42:33 nx9500-6C8809 DIAG PWRSPLY_FAIL Power supply redundancy failure 2019-02-21 13:32:29 nx9500-6C8809 DIAG PWRSPLY_FAIL Power supply redundancy failure 2019-02-21 13:22:25 nx9500-6C8809 DIAG PWRSPLY_FAIL Power supply redundancy failure 2019-02-21 13:12:21 nx9500-6C8809 DIAG PWRSPLY_FAIL Power supply redundancy failure 2019-02-21 13:02:18 nx9500-6C8809 DIAG PWRSPLY_FAIL Power supply redundancy failure 2019-02-21 12:52:10 nx9500-6C8809 DIAG PWRSPLY_FAIL Power supply redundancy failure --More-- nx9500-6C8809(config)#
nx9500-6C8809(config)#clear event-history
nx9500-6C8809(config)#show event-history EVENT HISTORY REPORT Generated on '2019-02-21 14:21:40 UTC' by 'admin' nx9500-6C8809(config)#
